What is this mystery potted component “PIC-10” and who made it (mic pre IC? VCA? Transistor array? early 80s)
zzzzz
GDIY Supporter
USA
I have dug for hours and can’t find anything about it. Has an “S” on it which looks like the old 70s Signetics logo, but I don’t think it’s Signetics. I know SSM made preamp ICs but those were in DIP packages and not discrete. It’s labeled as “PIC-10”(?) which could mean anything and could just be a house part number.
This is in a rare (but not necessarily desirable) Auditronics 110C transformerless mic preamp from 1982. From catalog pages, it looks like they were maybe using these encapsulated things in the 200 series broadcast consoles from the same era.
Looks to be a similar package to the blue Allison Research EGC-101 VCAs but with 14 pins and according to the schematic, it does use all 14 of those pins. https://www.studioelectronics.biz/sunshop/index.php?l=product_detail&p=4987
Some transformerless Auditronics equipment from the early 1980s used Allison Research/Valley People VCAs (blue modules) and Valley “Trans-Amp” modules (light green squares with the ). Sound Workshop also made black potted Trans-Amps around the same time, but the Trans-Amp pinout configurations don’t match this setup.
Here’s the full schematic for the mic pre, but obviously don’t have anything about the “PIC-10” itself:
    1.6 MB
    1.9 MB
    1.2 MB
    3.9 MB
*** package, not footprint. Typo on my end
the package is designed to plug into a 14 pin DIP socket... a common packaging trick*** to save labor if servicing is expected. Similarly if its a bunch of bipolar transistors the packaging makes them easier to test.
**** back in the day I recall one resistor company (Piher?) selling semi-custom resistor arrays packaged into 14 pin dip formats. I considered using these in a crossover design to program frequencies.
eventually once I can test these strips and see if any of them are dead (I might just repurpose them anyway -- long story), I'll try to de-pot one of the modules and see what's going on. really not having any luck finding anything comparable or manufacturer identification marks that match up.
Does the unit work? Maybe, before de-potting it, take some in-circuit measurements (DC & signal level) on various IC pins with a known input.
