StaticRick is right... they seem 1 second apart. So I started doing some searches on the web for EMI pulses 1 second apart, and got some interesting links. Searches with the terms RFI, EMI, HAM, and "1 Second" were useful.
Questions that arose are: Is the noise temperature or weather dependant? Is it time of day dependent (lunch hour? Closing time?). Is it seasonal?
My bet is on electric fence.
Here are the results of my search:
Case 1:
Fence - Lengthy description but in summary: a consumer installed electric fence product, with an arcing section due to corrosion. Has some good info on search technique.
http://www.qsl.net/n1lo/rfistory.txt
Case 2
Here is a document on searching for RFI (excerpts follow)
http://downloadfile.anritsu.com/RefFiles/en-us/Products-Solutions/RF-Interference-Hunting-Techniques.pdf
• Electric fences
Electric fences generate a short pulse of high voltage then turn it off for a
second or two. This allows shocked animals time to move away from the fence
before it shocks them again.
• Bakery ovens
Bakery ovens have high wattage heating elements, over 2,000 watts. The ovens
are typically regulated by turning the heating element on and off as needed
to maintain the desired temperature. This switching action generates impulse
noise.
• Welding
This is a large electric arc that starts and stops every time the welder draws a
bead. Need we say more?
• Electrical motors from elevators, floor buffers or even FAX machines
Many types of electric motors have brushes, which can create quite a bit of arcing and sparking. Have
you ever looked into the back end of an electric drill and seen the blue sparks around the brushes?
That’s a good example of impulse noise caused by an electric motor.
• Power lines, which may arc and spark
Have you ever been near a high voltage transmission line on a damp or foggy day?
Enough said.
• Light dimmers
Light dimmers operate by suddenly turning the AC power off part way through the power cycle of the
sine wave. This creates impulse noise. While these dimmers are filtered, filters may fail.
Case 3
Another HAM operator - with a list of suspects similar problem. No solution.
http://www.eham.net/ehamforum/smf/index.php?topic=56679.0
