Sammas
I have a TC 2290 on the bench... and it is a bit of a head scratcher. Symptoms = No sign of life. No lights. Nothing.
The PSU is nothing like I've seen before (usually just run of the mill linear psu stuff). Attached at the bottom are the schematics. I've never seen TIP31 & TIP32's before... what the heck are they? They are component number Q703 & Q705 on the schematic
And strangely enough... IC85 & IC86 are 7905 & 7805 regulators? For +/- 15v rails?
IC63 and IC84 are both LM324's.
The current state of the unit is, no lights at all. Regulators, Bridge rectifier and TIP31/32 are all brand spankers.
I'm getting an astronomical 22ish volts on the input of the 5v regulators. When I measure the voltage coming out of the transformer, I get 19ish volts AC between the primary and center tap (brown wire to black wire).
Any words of wisdom? I've never seen this unit functional. It could be dead as a doornail.
