john12ax7
In fact I had a rack with this problem
That is quite unusual. Which rack?
OSAThat is quite unusual. Which rack?
like that?Using back to back diodes works nicely. A beefy bridge rectifier also works, with AC sides to chassis ground and to circuit ground. + - terminals shorted with a fat copper wire to each other.
with the circuit common, what would happen if for some reason is exposed to mains voltage? If the transformer goes bad and passes 120/ 240 AC onto the secondaries for example
I still haven't quite understood why I want to do this and what problem it can help me with?
This way the signal ground is ~ 2V away from chassis ground.like that?
I still haven't quite understood why I want to do this and what problem it can help me with? I think with transformer balanced inputs and outputs you might not need it?
