thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Senarios where an AP / R+S / Prism etc. analyser is obviously worth having:
You're doing scientific work, such as Samuel did with his famous opamp paper
You're designing AD / DA converters and are engaged in a war of paper specs
Scenarios where you can use a much cheaper analyser such as a Lindos LA100:
You're a repair / modification engineer.
Small production of analogue items such as preamps / comps etc. The Lindos will run through a battery of FR / THD / Noise tests in a second and you'll know if it's ready for the outside world.
If item in question contains transformers... Small details will be swamped by the transformers' inherent distortion, so an analyser that goes down to a grillionth of a percent will be pointless
If someone in the latter group, i.e. those I suppose can do fine with a Lindos, were to purchase something like an AP, would it be anything other than an ego massage / way to impress clients? I have a nice digital scope and a Lindos - what else is to want? Why do I lust after an AP?
