dirkwright
- Joined
- Mar 24, 2012
- Messages
- 83
thermionic said:Usually when troubleshooting malfunctioning gear, it not about identifying some sputz a few zeros to the right of the decimal, but some much grosser error, and so easier to read.
That's exactly how I use the Lindos LA100. It goes to around 0.002% THD if memory serves me right. If I'm testing something that has THD below its threshold when working correctly, it's unlikely to have a fault that renders its THD somewhere between its correct figure and 0.002%.... Not impossible, but unlikely... I do crave a nice FFT, though. Something with a ROM-based OS that boots in seconds and gives me a similar resolution to an AP / Prism etc. Most issues revolve around noise and / or distortion - a low-distortion generator + high-res FFT will tell you if these problems exist in a millisecond. Much as the LA100 tells me when there's an issue, an FFT would potentially be more specific in pointing the figure.
I like this FFT software:
http://www.audiotester.de/
It does other things as well, and is shareware.
