We have two cables with this connector, one is for a KM256 and the other a KM54. Both mics have the correct connector going to the mic, this is the connector going into the PSU. When I pulled the connector apart to see about repair, pins started to fall out. I rather just replace the connector...From what microphone is that connector?
this one ?Is this a 7 pin din connector?
Make sure you buy the right make because most of the regular types are not rated above 50V.Yes. I do the 7 pin xlr’s on builds
Indeed. I may just stick with the 7 pin dins however when I pulled the connector part to have a look at it yesterday, pins started to come out so I had to be extra extra carful.Make sure you buy the right make because most of the regular types are not rated above 50V.
IAn
Hi Ian, I have often wondered about this. Obviously we all know that tube mics are made and sold that use these connectors. But I wonder if the very low current (<10ma) of the B+ means this spec is OK? Perhaps it is about total power, not actual voltage? Not like 150vdc is likely to arc! -MikeMake sure you buy the right make because most of the regular types are not rated above 50V.
IAn
well neutrik specsHi Ian, I have often wondered about this. Obviously we all know that tube mics are made and sold that use these connectors. But I wonder if the very low current (<10ma) of the B+ means this spec is OK? Perhaps it is about total power, not actual voltage? Not like 150vdc is likely to arc! -Mike
Rated current per contact | 5 A |
Rated voltage | < 50 V |
well neutrik specs
Rated current per contact 5 A Rated voltage < 50 V
but at a B+ thats a few ma I think it's o.k., many a company has used them without issue.
Rated current per contact | 16 A |
I use the four and five pin versions for PSU connectors for racking modules quite often when an external supply is required. I have not tried them on mic PSUs yet.No Love for the GX16 or GX20 Aviation Connectors?
It would be nice if the published a curve vs a "spec".^ right. I believe there would be a derating/uprating curve. It's always a voltage rating at a current.
