Dan Kennedy said:Send me an address, I'll throw some in the mail.
squarewave said:Nice work rackmonkey. This is exactly what I found in my limited study. There are two distinct and very consistent gain groupings with the real 2sk170's being quite a bit higher.
stason99 said:Can someone recommend a trusted ebay seller or another source? I need only 2-6 of these transistors.
So are the alleged "fakes" Field Effect Transistors ?squarewave said:.... the fakes are actually pretty good. .... the noise floor of the fakes was technically lower .... the fakes have less distortion. .....
If they're sold as "2SK170", that is a designation for a part with specific characteristics. The gain and noise differences are too significant to call those Bonzai and Ebay parts legitimate 2SK170. They are clearly another part entirely stamped with "K170" to look like 2SK170. If the parts were advertised as 2SK170 from a reputable manufacturer that had a website and a datasheet, then we could test those and debate their value as a second source. But non-branded transistors from Ebay seller yuwewe12345 do not qualify as second source.analogguru said:If they are FET's, don't wear a Toshiba symbol and fulfill the required 2SK170 specs (or even better) than they are NO FAKES, they are so called "second source".
mutterd said:what about the new Linear Systems ones?
http://www.linearsystems.com/product-search-result.html?type=products&partnumber=LSK170&match=true
stason99 said:I'd also like to know that.
Exactly, and this are the MINIMUM requirements.squarewave said:If they're sold as "2SK170", that is a designation for a part with specific characteristics.
You didn't answer my question:squarewave said:The gain and noise differences are too significant to call those Bonzai and Ebay parts legitimate 2SK170.
Here you are totally wrong, in reality it is like this:squarewave said:They are clearly another part entirely stamped with "K170" to look like 2SK170. If the parts were advertised as 2SK170 from a reputable manufacturer that had a website and a datasheet, then we could test those and debate their value as a second source. But non-branded transistors from Ebay seller yuwewe12345 do not qualify as second source.
You can't just find a part with the same numbers on a datasheet and then call it that part number. Even Linear Systems does not call their part "2SK170" and those parts have exactly the same gain characteristic as the Toshiba 2SK170. Look at rackmonkey's plot carefully. There are two very consistent and yet very different gain curves with the Toshiba and Linear Systems parts following one curve and the unbranded parts following the other.analogguru said:Exactly, and this are the MINIMUM requirements.
"And do the alleged "fakes" fulfill the specifications (= minimum requirements) of a 2SK170 ?"
Why do you think Linear Systems calls their parts "L SK170" and not e.g. "LSF578" ?squarewave said:You can't just find a part with the same numbers on a datasheet and then call it that part number. Even Linear Systems does not call their part "2SK170" and those parts have exactly the same gain characteristic as the Toshiba 2SK170.
Did you ever visit the Linear Systems plant where the LSK170 are allegedly produced ?squarewave said:Incidentally, the fact that there are two completely different manufacturers (Toshiba and Linear Systems) that make parts with the same exact gain....
Obviously you didn't read or understand my explanations concerning when a part can be called a e.g. "2Sxxxx or not.squarewave said:.... the various parameters are vaguely correct. But those parameters are not "requirements" to be called "2SK170".....
