Who can identify these audio connectors? 2/3 female 1/3 male
3/2 female 1/3 male
Sounds like a LEMO:
Its an old ORF mixer.  ORF used Lemo until the 80ies instead of XLR.
I have a few of those connectors available if you should decide to get the Mixer :)
Georg
A Sennheiser M101...
Never seen one of those with these connectors. Mine has XLR's, albeit male where inputs should have female connectors...
And T-12 power, of course.
@tonzauber
Yes it´s a M-101 from ORF (austrian broadcast) and I bought it already, and I may very well get back to you about the connectors soon, thanks ;)
@cyrano I have seen that version also, I measured and there seems to be just not enough faceplate place to put in female xlrs, swapping T12 for 48V is one of the few mods I will do on this mixer (I am just cleaning it up and restoring it now but plan to use it in mono), this one also has a nice big output transformer in the master channel (factory mod), also the specs of the mic input transformers are nowhere mentioned in the service manual.
The hp-filter uses transformer inductance as one filter pole (Audio Developments does this too): nice! The minimal EQ has tapped pots, everything is high quality and well engineerd, maybe I should get another one and put together a stereo version  ::)
@abbey road d´enfer
would you care to elaborate? I´d think exposing (phantom) voltage like that on open pins is suboptimal... (btw. I´m still all over that Soundcraft series one :D)
  • Sennheiser-M101 mix.pdf
L´Andratté said:
@abbey road d´enfer
The reasoning is that the source should use a protected connector, so an output should use a female, but mic inputs are ambiguous because they are a receiver AND a source when phantom or T-power is activated.
Phantom is generally assumed to be "safe", in studio, only professionals messing with the plugs.
Don't lick it. Don't throw the end in the musicians' hot-tub while they are strung-out on pep-pills.
Phantom is (should be!) designed to survive accidental shorts without harm.
When I first looked at it, I came to the same conclusion. But standard XLR's do fit in mine's inputs. Output is another story, being 7 pin DIN. I didn' bother looking for those connectors, just use the preamps without the master section.
I've considered a phantom mod too, but I use the preamps with old MKH816's and it would require an adapter or a mod to these too. And that's beyond my capabilities.
Yes. These are very nice. And quite rare, over here.
That´s good news,though it must be really tight squeeze! Did you have to drill out/file/whatever the inner faceplates? I´m not keen on that.
I maybe try to fit these:http://www.neutrik.com/de/industrie/xlr/mpr-hd-serie/nc3mpr-hd
And use a 5-pin of that for 4x unbal. direct out + GND
I think if you need 48v as well as t12 (I don´t), it´s really easy to keep both, you just need two switches...
Agreed and they pop up from time to time in Germany.
They run on 12,5V single sided (-12,5 really asit´s "positive ground"). That´s not too much headroom, but I think it will be fine-we´ll see ;D
I'm sorry, I meant that standard XLR plugs fit in my mixer. No need to change them. I just use a female to female adapter.
And these are special. Fastened with a ring, in stead of screws. Very nice, so I won't change them.
And since I have tapped the bus for outputs, I don't use the master section, so the 7-pin DIN connectors don't matter.
But mine is basically a two channel preamp, since only two work. But then I have only two MKH's with T12 power, so it's fine for my needs :)
I think if you need 48v as well as t12 (I don´t), it´s really easy to keep both, you just need two switches...Agreed and they pop up from time to time in Germany.
The schematic is different from most of today's stuff. An elaborate attenuator in front of the transformer and then a fixed high gain stage after it.
I wonder why a lot of these vintage audio devices seem to use positive to ground schemes?
I pondered on it, but I don't see any real advantage.
Oh, and headroom is fine. The way it levels out if you overdrive it, is euhm... nice?
Thanks for the insight, Abbey. Seems a simple enough reason. And this stuff is old enough  :p
