The main reason for having the highest value possible is not primarily to extend the LF response, it's to decrease perceived noise.
Math show that so-called KTC noise increases with the resistor value, so why would it result in less noise?
The reason is that although the noise energy increases, the audible part of it decreases. Noise density increases at a rate of 3dB for each doubling of the resistor, but, for a given capacitance, the response at audible frequencies decreases by 6dB, by shifting the cut-off frequency of the low-pass filter constituted be the resistor and capacitor.
Actually, built-in FET capsules have a rather large impedance. Most of the specs range about 600r to a few kohms. In fact, it's the power feed resistor that governs the specified impedance.
The capsules where the FET operates in their pentode region have a impedance of several tens of kiloohms, those that operate under very low voitage operate closer to the triode mode, with a slightly lower impedance.
