Hopefully this is a simple one for Kicad vets. I'm just getting used to it and transitioning from Eagle.
It looks as if some setting is forcing all of my pad holes to print at some tiny sub-mm size, though they look fine on screen. This is for default pads in modules, and ones I have manually altered. Even my mounting holes, which are set to something ridiculous like a 3mm hole are affected. Outside diameter of everything seems OK, and other than adding my own list of available trace widths, I think most of that stuff should still be at the defaults, so I'd think other people would be hitting it, but my searches haven't found a solution.
I'm running the 2013-5-31 BZR 4019 stable build of PCBNew
-Thanks!
-Thanks!
