They have been obviously used by many with so much success i could only dream of. I didn't mean to bash on people who do use them.My reasoning is pretty straightforward--I've used them for years in certain applications (i'm one of the rubes, apparently, who loves them outside kick drum). I'm quite accustomed to what they do.
I don't have one at home, would like something operationally-similar, and feel like I could put together something that'd satisfy me for a fraction of the price of a Neumann reissue.
I also really love them on guitar amp sometimes, frequently on Ampeg B15, and sometimes on the right vocalist--where I find them to be underrated.
One thing that makes them useful relative to a tube U47 for high-SPL applications is that they have a switchable pad built in (actually two!)
Assuming THD was an appropriate measure for perceptual distortion performance: the maximum SPL (0.5 % THD) of the U 47 fet circuit is 137 dB SPL according to the datasheet. Especially for the time of its inception, this seems to be a pretty high figure; nowadays, there may be slightly better performing options for condenser microphones (if that’s the desired type for this application). Most of the distortion is probably in the low-frequency range (due to the transformer), where human hearing is said to be less sensitive to detect distortion. Depending on the music style and if you don’t put the microphone too close to (or even inside) the kick drum, this might be totally sufficient.But if you really want a mic that can take high spl without increasing THD fet47 is a pretty lousy choice in purely technical sense.
You are certainly right with specified THD using a test signal at 1 kHz. A long time ago, I did pretty extensive electrical measurements of some select microphone circuits including THD vs frequency. THD was (granted, for these specific circuits) pretty much independent of frequency in the audio range (20 Hz to 20 kHz) except for transformer-based outputs.Specified THD % is for the circuit at 1K!, not the whole system including the capsule. The way pad is implemented it causes additional distortion, but you have to take capsule, pad, and fet into equation to come up with a figure. Uli described some of the effects here. The reason why most people don't like how pad sounds on this and many other mics. The capsule THD is not published by Neumann, and not included in that figure.
I don’t doubt it. But is that 10 %, 0.5 %, or even lower THD at 40 Hz and at which playback level? I suspect it’s unlikely to get the former while recording with a decent condenser microphone at reasonable levels.Really not sure what you mean human ear is not sensitive to distortion in low end. I can't stand distortion in lower end, which is exactly the reason why i stay away from fet47 on low end sources.
For drums I would think a follower stage would be better
