> Vari-mu tubes (and FET's) are more linear but still have large dispersion
They are not linear in the right way. The dB/Volt is almost linear; exponential. Rectifiers are essentially linear. So we need a LOG function. The easiest way to get that, with just tubes, is feedback around a dB/Volt stage. And as long as you are doing that, it is a feedback limiter anyway.
Same with opto, which loosely follow an exponential; in fact I think that is how my concert limiter works (I forget). Wrap NFB around the LED/opto and it does what you want. Wire two matched LED/optos together, the second one does what the first one is forced to do. Switch some connections, you tap the signal "before" the program-path loss-cell. But it is still a feedback system.
Oh yeah, great dispersion from one device to the next! (I think I spent a season sorting photoresistors into sorta-match bins.)
Any curve can be approximated with linear over some range. There is an Australian "cathode follower" feedforward limiter which:
1) uses cathode feedback to linearize the tube's exponential
2) approximates quite well over a 10dB range but goes way off course beyond ~~20dB
As you say, the excellent LOG-conformity of BJTs (or linear PWM like my Fostex or some broadcast program processors) is what makes feedforward practical.
And I bet, for small amounts of limiting, FB and FF give the same result. The difference is that useful FF is necessarily a very precise processor, while useful FB can be implemented with fairly sloppy techniques. We praised FF, not because it was FF, but because it had very low error. (And because you can push it insanely far without NFB instability.) When that got boring, we swung back to FB, calling the errors "flavor".
Now ANdyP wants to mix-and-match the loose linearity of tube/opto control with the loose action of feed-forward. My suspicion is:
1) it won't work well, incredibly soft knee and erratic "limiting" level
2) by the time you make it useful, you will have either NFB or a super-computer
3) you lost the sweet simplicity and natural action
The FET seems more suited for feedforward. It is an exponential, but silicon FETs follow square-law very-very closely over a wide range. Much better than an exponential approximation to real tubes and photoresistors. Therefore a sharp log-law conversion between linear rectifier and gate ought to give a total response so predictable that feedforward "works". But much of the point of FET limiters is their simplicity. Stick a log-law in the works, you are as complex as a Blackmer but not quite so precise.
