Potato Cakes
Hello, everyone.
I need to make a replacement PSU cable that uses a 7 pin XLR, but I'm not quite sure which kind of wire to use. I looked at some of the tube mic PSU cable as a couple of conductors are larger and seem appropriate for the +/- rails. My hangup is the PSU fuses for the power rails are rated at 10amps, and I don't know if the gauge of wire needed for proper heat dissipation for DC is the same for AC. The console is a TAC Scorpion 24x16 that is being fixed up with potentially higher draw chips. The distance of the PSU to the console will be about 30 feet. Any insight would be appreciated.
Paul
Paul
