Apologies if this has been asked before many a time...
Is there any inherent problem in using wirewounds in audio signal parts of circuits ?
Can the inductance interact with other local components and result in a tuned oscillation or somesuch ?
Also, how much real difference in inductance is there between a wirewound and a metal film resistor, given that when i have scratched off the outer coatings of some metal films I have found a spiral film layer, which presumably also has inductance.
I just ask since I have a large pile of old style 5W green enamel coated wirewounds (various values less than 10K) and I was wondering if I could find some use for them in a tube build I am working on at the moment (namely the Redd 47 pre). I had already figured I will need a 5W-10W wirewound for the plate dropper resistor, but I was wondering what the effect would be of using wirewounds in other parts of this circuit.
Also, I wonder are wirewounds more or less reliable over time than metal films of the same wattage rating ? I would have thought wirewounds would be more beefy, but think I can recall some people saying wirewounds can vibrate and perhaps that would lead to internal breakage. (?)
Noisewise, I would have thought WW's would win the day in audio circuits, but of course there are many more other considerations than just noise to take into account. I rarely see WW's used in audio signal parts of circuits so there must be some reason not to use them.
Curious to know what those reasons might be.
