Working out math for the wrong answer
pucho812
third stone from the sun
On of the local knuckleheads  wired up  some we111c transformers in a box to run across his mix bus.  He insists that they are 1:4, 150:600. Looking at the data sheet can wire them 1:1/600:600 or 150:600 which would be one to two.  He insists 150 x 4 = 600 so it’s a 1:4. What the hell?🙈🙉
Decibels were originally created to represent power ratios.  They kind of don't make sense for describing transformer turns ratios since power in= power out (more or less).
A 1:2 turns ratio to preserve constant power means that the 2x voltage will only deliver 1/2 the current to maintain constant power.  As I shared already for effective impedance 2x voltage translates to 4x impedance to maintain constant power.
Sooooo a 150/600 ohm transformer would be 1:2 voltage ratio.....
Confused yet, I am... ;D
Transformer ratio is generally quoted as the turns ratio, same as voltage ratio. Impedance ratio is (N2/N1)².
In the case of a 150:600 ohm xfmr, the ratio N2/N1 is square root of Z2/Z1
Your chap is wrong.
Your chap is wrong.
I agree. I even showed him the math and the rest but nope.  As jr pointed out double of voltage, so 1 volt in and output would be 2 volts at half the current.
I wouldn’t care except he made two cardinal sins.
1. He tried to take credit  for a session at the studio that he was never at. Well known session with a well known artist with lots of photos and tried to tell us he was there. He wasn’t.
2. He writes gear reviews in well circulated audio magazine😬😬😬😬
He could argue he was giving distant mental support...Nothing stops mythomaniacs.
Well circulated doesn't mean credible anymore.
"Those who can, do; those who can't, teach write"
Impedance ratio is Zp/Zs or (Np/Ns)2.
Flatter him. Tell him he is right. Then tell him you have a special sharpie. All he needs do is run it round the edge of all the vintage CDs/SACDs he has in his collection and it will instantly create a 3D sound stage with added clarity of every instrument. etc etc As a special favour to him he can have it for only $1000.
Isn't it the same as"Impedance ratio is (N2/N1)²."
No. It's not mathematically correct. After you, the impedance ratio of 150:600 transformer is 4:1, not 1:4 which is correct.
ruffrecords said:
Flatter him. Tell him he is right. The tell him you have a special sharpie. All he needs do is run it round the edge of all the vintage CDs/SACDs he has in his collection and it will instantly create a 3D sound stage with added clarity of every instrument. etc etc As a special favour to him he can have it for only $1000.
You forgot green pen.
