Hello!
I recently got a pair of WSW 601-432C compressor / limiter modules. They require a 50-db preamp to operate, and I am trying to set them up with either WSW 811402 or 811403 amps. However, I'm a little confused about how to actually connect these, and so far I've only managed to get a very distorted (albeit rather cool sounding) signal out of them.
Does anyone have any experience with these and know what the proper hookup is? The documentation that I've been able to track down isn't clear to me. In one block diagram (below), it seems to show the preamp's output returning to the compressor across a trio of resistors, while the manual for the compressor suggests that there should be separate links from the preamp to the compressor's output stage (off of the amp's output trafo primary) and the detector (off of the amp's OT secondary.)
I've tried connecting them with three resistors as described in the block diagram, and I get distorted audio. Any suggestions?
