...or look for the identical European equivalent ECC180.
I took another look at the data sheets. ECC180/6BQ7 and 6BQ7A are virtually identical to the 6BC8 in terms of the relevant technical data. I would not hesitate for a second to exchange them for each other. Try it out, nothing can break. See if you like the control behaviour of the tube. Ultimately, the result in the circuit is what counts.So I guess the ECC180 is the same as the 6BQ7A,
but are those tubes really the same as 6BC8/6BZ8?
Or are they just similar or somewhat equivalent?
The 6BZ8 you mentioned is a bit further away in terms of technical data. The gain is somewhat higher at 45 (6BC8=35) and the transconductance varies.
I was also surprised for the same reasons. But these specifications in the data sheets are static values and they only tell half the truth, especially for a semi-remote cutoff triode. The gain differences are rather small and what really counts is the control behaviour in reality. The curves in the data sheet are probably more informative.I didn't know that and it's very strange as everywhere I checked the 6BC8 and 6BZ8 are referenced as the same.
This question is off topic, but I couldn't find a better place to ask.
Does anyone know the model number of the Cinemag interstage transformer?
Thank you!
Ok. The reason I asked here is because the OP said he had one in his possession.Best place to ask is doing your own thread in the LAB section, not here for sure
