Wanted WTB Bulgin 3-prong power connectors, cable mount.
Disco Volante
Southern Denmark, Fyn
If anybody has a couple of the bigger older (22mm approx.) models I'd be delighted to undertake ownership of said connector. I need the female cable mounted type, for a pair of Quad ESL57's.
0631 is definitely too small and only rated at 50V.
The 0646 model on the other hand might fit; the drawing is a bit unclear and doesn't state the pin spacing.
At £6.46 I might just order a couple and see what they're like. They might end up fitting the smaller connectors in the Quad amps, which would be quite handy.
The bigger version I'm looking for is supposedly NLA, so I thought some of you geeks out there might have one or two in a drawer...
Cheers, Viggo
Apologies.I should have checked the rating for the 0631.
However, I have actually used the 0646 on a two slot 500 rack with onboard power supply. You may consider replacing the panel plug on the amp too.
