nielsk
Finally found a use for these and need a few more.
Have any pulls from upgrades on the shelf?
Interesting. What is the evidence of their CHinese origin?Its a Chinese made transformers used in Neve clones...golden age audio, chameleon and alctron uses them.
I don't know about other brands, but I have 2 output transformers from a Golden Age 73 Mic pre, that were replaced in the circuit by Carnhill transformers, and yes they're completely Chinese made.
I actually opened one of them and they skipped in every detail of the original transformer, they just did it as cheap as it was possible:
Wire is thinner and looks pretty cheap too, there's less turns in primary and secondary, no reverse wound Primary, no insulation between sections, very thin a low quality plastic bobbin
I have to do a thread about unwinding that transformer and compare the data with one original one or one Carnhill.
here's the ChiNeve Ian:
Are you sure there is reverse wound in primary and insulation between sections on the current Carnhills?
I never unwound a Carnhill, only Marinair. I would expect so…
But do you have any info on that?
Wouldn't this be a fun project use the parts and re wound the transformer according to carnhill specs? Maybe CJ would give us advice?
CJ has unwound many Neve transformers. The info is probably on here somewhere in the transformers meta.No, unfortunately I don't have any info. That's why I asked, hoping you or somebody else has some info on the Carnhill ones.
Neve transformers were made by Marinair and St Ives Windings. St Ives was bought by Carnhill and the same production line still makes the Neve transformers; they just have different numbers now.By "neve transformers" you mean Marinair or Carnhill? My question was specifically for the Carnhill ones.
