bryceyoungstudios
New member
- Joined
- Nov 5, 2011
- Messages
- 2
I actually reverse engineered the 80100 about a year ago, I love the Yamaha sound. The transistors are a bit harder to come by than some of the other DIY opamps I've seen but they were attainable. I even had a pcb printed with the opamp and ordered parts but have been too busy with other projects to actually build and test the 80100. The PCB has the 312 circuit, the JLM AC/DC the JLM HI-Z and the 80100, I reverse engineered them all onto 1 pcb, I also made holes to pop in your own DOA if you don't want to use the 80100 built into the board, needless to say it's a SWEET board. All of the board has been tested except for the 80100, so I have used the power supply and the rest of the circuit without any problems, but I've always popped my own DOA's in the board when using it. If you guys want the eagle files I'm cool with that I just don't have time to answer a lot of questions it would really be up to you to analyze the board and figure out what hole is what, everything is labeled with part numbers so it shouldn't be hard to figure it out.
All I ask is that some one give me a heads up next time they see a yamaha board available at a good price, the models I would look for would be PM-1000, PM-430, M1516, M1524, M1532? I just don't have the time to build DOA's so I'd prefer to get some old school yamaha's that I can desolder and pop into my boards. Either way, hit me up if you want these files email is bryceyoungstudios at gmail dot com
