rjb5191
A little background. I'm modifying a Yamaha PM-430 with discrete opamps in place of the TA7136 IC's and they draw more current. As I add more opamps, the +/- 15V rails drop a little by little.
If you take a look at the power supply in the schematic on page 5 of the service manual (attached), you can see the voltage divider formed by the 47R and 3.3k fusible resistors to drop the supply voltage from +/- 22 to +/- 15. I've attempted to use online voltage divider calculators but they are not working for this application.
I've already experimented by replacing the 47R resistors with lower values. I've already gone down to 22R which has helped to raise the voltage back up but I know this is also reducing ripple reduction as part of the RC filter there.
So, my question is in regard to the 3.3K resistors to ground. These must be bleeding off current to ground but I'm guessing it is a small fraction of what is passing through the 47R, I just do not know how much!
How do I properly calculate this?
Will raising the 3.3K resistors have much effect? What about negative effects?
What is the most efficient way to design this section without having to resort to using active devices? I would like +/-17V output if possible,
