wilcofan
Active member
Anyone know how to mod direct outs on a PM1000 input channel?
1. I want direct outs, even if unbalanced at first. This is easy. You just tap off of C37.
1 http://www.krashjones.com/pm1000/ Go to the bottom and he talks about altering the EQ points. Very good reading!
2. http://www.opamplabs.com/cfl.htm Here is a online Java based LC calculator. you can plug in your own values. Keep in mind that when you use the calculator, it will spit out very precise values. In real life you will have to round up or down for commonly used capacitor values.
tubejay said:I can't help you with your transformer question, but I too would love to know...
Elco passed me a link, that anyone working on a PM1000 should check out. It talks about changing the EQ points to that of Neve or API, to help make the EQ more useful. I asked about this over at TT, and nobody knew, so this is good info:
Elco also had this link with info on how to calculate the EQ points based on the value of the inductor, and the frequency you'd like to end up with.
Thanks Elco, that information is SUPERB!! I had a nice read last night...
