radardoug
I work all the time with Protools going digitally into a Yamaha 02R. Mix outside the box. Do tracking that way too. It works well.
I was referring to recording to multitrack tape, and then mixing down to two track tape. I know that can be controversial these daysbut it is my preferred method of recording and mixing music.
Yes, I did. It was a pretty straightforward case of some of the links between the backplane boards having bad solder joints. Here's what you need to know:Hi Ike,
Did you end up checking out the console for your client last week? Would love to get any insights if you did some work on one. Thank you
Good question. I’ve been going through and cleaning my board module by module, so I’ll see if there’s anything to identify it with. I’ll have the whole board apart soon and can let you know. I take it you are also a PM2000 owner? Let me know if you have a Foldback Headphone module for saleI’ll jump in with a PM2000 question (like the topic of this thread suggests). I’m curious to know how old my board is. What is the best way to date a PM2000? With old guitar amps I would commonly look at the stamped identifiers on the pots (among other things). That’s not the case with these ”Made in Japan” labels printed on the pots. What should I be referencing?
Integrated circuit date codes are always useful indicators. While some ICs may have been stored up at the factory before being installed onto a PCB
If you pull the modules out, there will be a sticker on the the top of the connection panel. The sticker will have a lot number, which should be the year and then the month.I’ll jump in with a PM2000 question (like the topic of this thread suggests). I’m curious to know how old my board is. What is the best way to date a PM2000? With old guitar amps I would commonly look at the stamped identifiers on the pots (among other things). That’s not the case with these ”Made in Japan” labels printed on the pots. What should I be referencing?
No, there are a lot of IC... far too many! I have the 24 trcks version and If I want to upgrade them all (HA1457), I have 237 IC to swap! Of course, I will only change them as they break. Fortunately, Chris Mitchell (Flying Eye Productions) has a wonderful site in which he shares nice tricks to upgrade the PM2K and I think he still sell inductors EQ and upgraded IC for this console. He’s a great and very helpful guy!Are they any IC's on a PM2000 of it's completely discreet?
I’m still trying to track down this elusive Foldback / Headphone module for my PM2000. Anybody have a creative workaround recommendation?
Yes, I have schematics. Unfortunately it’s a bit over my head doing something with regard to the module, but I’m all ears if anybody has some ideas.Do you have the schematics for the console?
Are they available?
If you have them then it will not be difficult to DIY the Foldback / Headphone module, problem solved
Good idea!Post the schematic of the missing module?
Bri
