pucho812
This is a good one. We have a rev7 at the studio and first power up of the day, the unit will run about 4 hours before it stops with the reverb and just passes dry signal. When the unit stops reverb, the screen will show the yamaha logo, initial start up logo, and stay there while the background of the lcd screen flickers. I pulled the unit apart and found a bad BP lytic cap and a leaking cap in the PSU. I see +/-15VDC and 5VDC as I should from the power supply but over time the 5V line will start to drop when under load, slowly but surely until it's below minimum operating voltage of the things. I have brought it back buy adjusting the trim pot, but this is a temp fix as the unit will start to drop the 5V down under load right away.
Has anyone seen this before? I am certain it's a power supply issue and or something is going into thermal shutdown.
