And the kicker is that a couple of months ago, when I started this build, I thought the preliminary 0.002% THD result was really good ;D ;D
Since then I've spent a lot more time measuring various discrete and integrated solid state gain stages .... I *was* mostly accustomed to tube amp stage THD measures.
Now, my opamp test rig, with debalance-balance stages is showing 0.00023% at +4dBu (returning an additional +6dB of drv134 level shift and a further +1.6dB at the drv134 due to 10K-ish loading ) which is basically no added THD over the measurement channel!
Interestingly, I was able to measure an improvement in the debalancing stage with the LME49860 dual-opamp over an NE5534 dual-opamp .. of about 10 pips ie. down from 0.00033 -> 0.00023.
Not a heap but still .. significant ... for the extra 3.00usd for a *genuine* us sourced part.
Similar result when I patched a variable gain stage, unbalanced, into the opamp test rig .. an improvement of around 10 pips over the standard 5534.
To go lower than that I need to buy a new Motu audio interface - they have a new one now which has awesome double plus good performance .. the Motu 624
For the 800usd or so street price, it quotes super performance.
SO, I appear to have found my analog boundaries!
AND for some real giggles, I tested the digital interface on the Motu with a Finaliser Plus into REW.
Kind of gets things into perspective ....
