All things LA2a related
so i'm in trouble shooting mode for my p2p build based on Cayocosta layout. first problem seem to be that none of my tubes will fire except the 6aq5 (v4). i'm getting 3.49v on all of my filaments for all the tubes. i have the hammond 369jx power transformer with the sowter i/o transformers. any ideas? thanks so much!
You're measuring AC on those heaters right?  The most common problem with the P2P build that ive run into (ive only done 3) is a ground missing somewhere.  Every build I've done, theres been one ground somewhere that was off, gummed up the whole thing.
I have a problem with my P2P LA2a. All tubes work and the voltages below. I am having oscillation issues with the unit. I do not have any grid stoppers installed and using a Sowter in place of T1 (HA100X). In +10 mode the meter just jumps. Gain reduction position and the meter does not go to zero. Cannot get sound to pass thru unit. Also the gain reduction does not function on the meter.
C7C - 191V
C7D - 115V
C7B -262V
R29 - 350V
R34 - 262V
Across NE - 52V
12ax7#1
Pin 1 - 98V
3- 1.0V
6 - 100V
8 - 1.03V
12BH7A
Pin 1 - 109V
3 - 3.5V
6 - 209V
7 - 31V (*) not normal according to what I read. Before R15 voltage is 109
8 - 113
12ax7 #2
Pin 1 - 100V
3 - 0.7V
6 - 100V
8 - 0.8V
6AQ5A
Pin 2 6.8V
5 - 118V
6 - 107V
Any thoughts?
Hi
Which tube socket, base, shield combination will work with the 6aq5a and where to source it? It apears to be a tall tube and everything I found seems to be for shorter tubes.
Put a test tone into the unit and carefully test if the signal makes it to the secondaries of your input transformer (ie start at the input end of the circuit) then continue breaking the circuit into logical chunks and start tracing, using the schematic and a highlighter to keep track of where you have traced.
C7C - 191V
C7D - 115V
C7B -262V
R29 - 350V
R34 - 262V
Across NE - 52V
12ax7#1
Pin 1 - 98V
3- 1.0V
6 - 100V
8 - 1.03V
12BH7A
Pin 1 - 109V
3 - 3.5V
6 - 209V
8 - 113
12ax7 #2
Pin 1 - 100V
3 - 0.7V
6 - 100V
8 - 0.8V
6AQ5A
Pin 2 6.8V
5 - 118V
6 - 107V
Any thoughts?
I have some basic questions …
Anyone tried UTC LS-50 as output? There is also the black version of this tx… it looks like the case is being handmade at blacksmith's…  :)
Would these (the black LS versions) be anyhow superior to "ordinary" grey version (like A series) or it doesn't matter?
(by superior I mean more vintage sound)
I have a problem with my LA-2A ptp build
For the second time V1 has broken and the compressor started to sound distorted
I replaced V1 with a fresh one and the compressor sounds fine, but voltages on V1 and V3 are not good compared to the recommended values
V1
1-  168V
3-  0.8V
6-  202V
8-  0.3V
V2
1-  97V
3-  2.9V
6-  222V
7-  75V
8-  102V
V3
1- 168V
3-  0.4V
6-  168V
8-  0.4V
V4
2-  6.4V
5-  128V
6-  117V
I am wondering what is causing V1 to break ? I have triple checked all the wiring and components and everything is fine.
Can someone help me pinpoint the problem ?
I would check again along the cayocosta layout AND the schematic. A lot of time, it's a missing ground point/wire. Something is sucking out too much current. Check your résistors values. I had trouble with voltages once and it was a missing ground wire. I found best to take a highliner and trace over the layout as you check all components. That way, if their is something missing, you'll know. When I cross a resistor, I validate it's values before going further.
hi deepdark,
i have checked a lot of times and i am sure all the components values and connections are fine
i am afraid i have a damaged resistor or capacitor along the line, i can't figure out what is wrong
the compressor works and sounds fine, but with that high voltage on v1 and v3 these tubes are going to break again i guess
is there any way i can isolate the sections and narrow the problem ?
about R34, be sure it's rated 2W. I even place a 1/2W instead of a 2W and my voltages were higher than they add to.
Oh and also, check R10, R12, R14 and R31 and R22.
all the resistors checked again and their values are exact. they measure ok with multimeter so i think none of them are burnt
i did the full check with schematic and layout on hand and again everything appears to be fine
i can't really figure out what's happening here !
in the meantime another 12ax7 has been damaged
something is wrong for sur. Check to be sure to have not a resistor that could touch another pin, ground turret, etc. it's seems to have too much current passing by the 12ax7. If possible, strap your DMM in series before the 4k7, between the 2 power caps. A LA2A should take about 15ma.
i have checked many times for shorts, missing connections, wrong component values. everything is right
maybe 12bh7 tube is bad ? although voltages are fine... this is the only tube i didn't try to replace, because i don't have another one.
i am thinking if there is any way to isolate the sections and try to make them work step by step
the problem is very hard to spot, i've lost so many hours trying to find it
i am totally stuck with this, it's been the most painful build i've ever done
Can you take some pics please? Also,  thé 12bh7 is the last stahe of thé amp section. There is a feedback circuit connected between it and thé first 12ax (the first stage of the amp section.). You can look around thé feedback section but i doubt thé culprit is there. I dont think thé 12bh is bad.
