matta
Hey Guys
As promised in another post, here is a quick comparison between the Digi 002R Pres and the Green.
Acoustic Guitar through the 002R Pre (1.5MB, 16 Bit, 44.1Khz, Mono)
Acoustic Guitar through the Green (1.5MB, 16 Bit, 44.1Khz, Mono)
A bit of background, the clips have the pres using no low cuts, there is no EQ nor compression, just the raw mic and pre combo. The Mic was an ADK-51 (stock, no mods) pointed at the 12th Fret of the guitar, about a foot away from the sound hole. I only had the one mic handy so it is 2 separate passes, but I tried my utmost to match the same position and rough levels inside of Pro Tools.
This is very rudimentary, but I think gives a basic pic of what is going on. I take back what I said in the previous post with the mids being cut on the 002R (what mids!). I normally use a low cut, but since the low cuts on both pres are different I left them both out, hence the slight boom.
I hope you enjoy, again this was very quick DIY recording. I'll be doing a 'professional' shoot out in August with Green and a few others with similar, and different topologies.
But it might help some Newbies and even oldies compare the 2.
Matt
Matt
