It is always a PITA working US gear in the UK. There is no simple solution. The best answer long term solution is to replace the mains transformer. I have a Maplin step down transformer that I use for US gear.untune said:It dawned on me yesterday that I can't just wire straight into the power transformer (117v pri) which people often do with these units in the States... I'll have to keep the original voltage selector and step down in place too, unless I opt for an external step down... I do have one somewhere. Any advantages to that?
Because a DI input is high impedance it is susceptible to picking up interference. You should therefore keep connections to it as short a possible. Switching from on stage to another will make this difficult .I'm still in the midst of updating the schematic, removing the necessary components etc. Hoping to get it done in the next few days, time permitting. I was looking at inserting the DI input between the volume pot and 2nd 6au6. Also pondering if it might be interesting to make it switchable so it can be inserted at either the first or second tube stage.
Sounds good.In terms of the tone control I might go for a variable HPF, and rework the switch to bring it in or out.
PRRs advice was very good. You don't need the power the stage can deliver at present and his method will allow you to use a good quality pro audio transformer.I'll have to do some serious reading up in regards to the output transformer as it's all very new to me. Thanks for the info PRR, I just have to work out how it all appliesI'm also wondering if I might be able to insert an output level control, so that I can overdrive the input and attenuate the output.
An output control is straightforward. It can be as simple as a 1K log pot connected across the transformer secondary.
IAn
