college101
SO my cd output is low, and thats why it is showing -20, and then bumping up on the louder parts of the songs!? That sounds right!
I know I am monitoring the output
lassoharp said:+4 is supposed to be -20 ? HUH...im lost
+4 will read +4 when there's that much signal passing through . . . . when there is no signal passing, it should read something else . . .
college101 said:SO my cd output is low, and thats why it is showing -20, and then bumping up on the louder parts of the songs!? That sounds right!
emrr said:Every vintage design tube vari-mu limiter I've ever worked with requires anywhere from 2-5 hours before one can align the meters and walk away, expecting zero to be at the same point upon return. That's about the amount of time required for temperature to stabilize.
There's nothing audiophoolery about it. Likewise, none of this should prevent you from working immediately either.
Biasrocks said:This is the type of phoolery I was referring too.
http://www.haglabs.com/frydaddy.html
college101 said:So I dont need to test the meter then, I need to figure out why I am getting no signal when in Gr mode then...
college101 said:Adjusting the gain control will do nothing at -20...Right?
college101 said:right now, if I have my cd player set to the max output level(cranked) adjusting the controls doesn't really change anything Im hearing...Im geussing that is because the level is so low...so low I cant hear the adjustments occuring...
The needle does bounce around..but its very little compared to what I was expecting...
