I'll point out the obvious just in case it isn't obvious. Loudness and level are not the same. They are intertwined but not the same. Most of what a mastering engineer does is prepare the audio in a way that enhances the sound but also makes it behave better in real world situations. This is usually called translation. If I'm working on something and I make it sound louder but it is sitting on the meters the same way or lower I know I'm on the right track. Not for all music but most.
A 670 could make something sound louder at a given level or it could make it sound lower at a given level. It depends on the material and the settings.
Undoubtedly a digital brick wall limiter is needed to get to modern levels, but if you make the limiter work hard it won't sound very good. That's why you need to get it right before hitting the limiter.
