Any reasons not to use a SS diode instead of a 6AL5 in a sidechain of an RS124-type compressor?
MaxDM
I have a couple NOS 6AL5, but just realized I don't have a 7-pin socket handy for it...
Why not just use high-voltage diodes instead?
or... is there a tube I can buy in a 9-pin package that will do the same job?
It's been years since I fiddled with a 6AL5 and I already drilled and installed a 9-pin socket..
Silly of me, I know.
I suppose I could use a couple of diodes, given that the sidechain is threshold-dependent, so who cares about the 0.6V drop, and there is the 33K resistor in series, so the internal resistance of the 6AL5 would not have made much of a difference anyway.
So either I seal up the extra hole I made (DAMMIT), or I suppose I could use it to put a 6386 in there (I have a couple) as an 'alternative' tube to pick between the two, or maybe to put another 6BC8 in parallel..
Or I could get a 7-pin socket and adapt the hole :(
Just in case.. Does anyone here have one in Northern Europe to sell?
yep.. have you got the shield for that?
Can you please give me the measurement from screw-hole to screw-hole?
I need to check if it will fit in the hole or if I need to do something else
