the wrong way no doubt :
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
but it works for my set up
take the front panel off
disconnect the molex from the main pcb
each xlr now has three pins clearly viable on the back of the F/P pcb
theres 5 wires to the molex, single red and 4 black
red is Hot, black next to it is Cold and middle black is shield (Think thats it, but best to check continuity to be sure)
theres an smd thingy in line with each of the pin tracks, unsolder them and check that the pins are now isolated
get a soldering iron nice and hot and heat each of the pins till it flows and insert a wire into each (there hollow
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
now clip the red wire and the first two black wires (immediately next to the red)
solder a resistor in to each of the lines*
reconnect the molex and reassemble
voila, plug your outboard in and go for it, the signal and clip meters still work as well.
*cant remember the size of resistor I used here, the totally unscientific method I used was to connect the front and rear xlr's together via a mic lead, played a tone through my daw and recorded it back in, set the resistor to a level where the recorded tone came in at the same level as the played tone.
I use the daw's metering for my levels and not had a prob yet, when I get more time I might experiment again to see how a lower resistor works, but my DIY skills arn't at smd levels so further mods are unlikely here
Iain
