Hairball Audio said:blackartmixing said:could you give me a quick explanation of how to check the voltages please? where should i connect the red and black leads from my DWW?? and what should i expect to see? thanks
http://mnats.net/files/1176REVA_125_VOLTAGES.pdf
Put your black on common again, test for DC, google/datasheets will help you identify leads.
blackartmixing said:so i figured out how to take the readingsmall victories and learning a lot. the only place where is seems to be a bit suspect is Q4. i get 1.76 on the pin nearest the front panel, 4.18 on the middle and 12.73 on the far pin. according to the schematic it should be 6.6V and 13.72V so my values seems pretty low. strangely i had a J309 transistor spare so i swapped it out with that but still the same issue. I checked all the transistors and they are the correct type. any ideas what i should check next?
Hairball Audio said:blackartmixing said:so i figured out how to take the readingsmall victories and learning a lot. the only place where is seems to be a bit suspect is Q4. i get 1.76 on the pin nearest the front panel, 4.18 on the middle and 12.73 on the far pin. according to the schematic it should be 6.6V and 13.72V so my values seems pretty low. strangely i had a J309 transistor spare so i swapped it out with that but still the same issue. I checked all the transistors and they are the correct type. any ideas what i should check next?
Check all the transistor values. Re-flow any odd joints.
Mike
blackartmixing said:Hairball Audio said:blackartmixing said:so i figured out how to take the readingsmall victories and learning a lot. the only place where is seems to be a bit suspect is Q4. i get 1.76 on the pin nearest the front panel, 4.18 on the middle and 12.73 on the far pin. according to the schematic it should be 6.6V and 13.72V so my values seems pretty low. strangely i had a J309 transistor spare so i swapped it out with that but still the same issue. I checked all the transistors and they are the correct type. any ideas what i should check next?
Mike
as i said above i have checked all the transistors and they seem to measure correctly according to the schematic except possibly at Q4. in your opinion do the values above look incorrect? or should i look somewhere else?
tata said:Ragan,
i think you do the best if if re-measure every singe resistor before soldering them in. when your DMM shows "1" that usually means the value is higher than the measurement range, so you gotta change the range. for eg you cant measure a 22k at in the 20k range, that shows "1". you need to set it to 200k range.
the blue Bourns things are trimmers. (multiturn, miniature potentiometers)
tata said:whats the best way to get +24VDC for a pair of DPDT relays in rev.A, please?
should i get it from the 7824, from the +30V rail with another stabilizer added, or a separate PSU from the AC trafo?
is +29.1V enough on the +30V rail (loaded, w/the VU lamp too)? i use a 2x24V 50VA trafo.
thanks
tata said:blackartmixing : if you used a 5% tolerance resistor there, its still out of the tolerance range
Low Tolerance Value: 14250000 Ohm
High Tolerance Value: 15750000 Ohm
did you measure it out of the circuit?
could you please tell me whats the best S/N we can have with rev.A rack builds? i know its not "LN", but im very curious if i should fight for less noise - or this amount of noise is a "feature".
my observation is the input gain doesnt really affect the overall noise, its coming from the out amp i guess?
Q6 gets very hot (tho i have a small heatsink on it). i guess thats normal, but.. this hot?
i dont see much buzz/hum on the output, its mostly white (?) noise.
