[BUILD] 1176LN Rev D DIY
mgalimbe said:
mgalimbe said:
could you give me a rundown on how test those transistors. I'm going to double check the output pot wiring and look for cold solder joints now
Checked my wiring its fine and I went over all of the solder joints in the pre amp section just to make sure. Still getting 0v at C7. Just waiting for guidance on the transistor testing.
Compair the values on Q3, Q4, and Q14 to here:
http://mnats.net/files/1176REVD_VOLTS.pdf
You're measuring DC, unit on, no signal, referencing ground/common/0V whatever you want to call it.
Mike
also could it be a bad output pot?
Doubtful. Stuff like pots, transformers and other passives are HARD to damage. Semi conductors like diodes and transistors are VERY EASY to damage with static electricity and high soldering heat.
Mike
Mike
Ok thanks so how do I go about testing those transistors.
Mike
Posted the answer a few posts above.
my apologies I missed it
So here are the values Q3
should be :12.5 getting: 1.78
"                  ":1.15 Getting 1.15 (ok)
Q4
all match up but 2 in different pin locations Ex: on mnats middle pin should be1.02 but reading 4.65, pin closest to c10 should be 4.2 but read 1.01 last pin should be .46  and it reads .42 so the middle pin and the pin closest to C10 are reading backwards.
Q14
should read 12 v but getting 10.47
Q4
Q14
The pins on the schematic don't match the pins on the PCB. You'll need to google the datasheet for each transistor and look at the drawing in the datasheet to figure out what is the base, emitter, and collector. It's super easy.
Q4
Q14
Ok so here are the numbers as it relates to the proper pinout. The first number is what it should read and the second is what it actually reads:
Q3
B1.75      1.78
E1.15      1.15
C12.5    11.2
Q14
B12.5  11.1
E12        10.4
C30      29.06
Q4
B1.02    1
E.46        .42
C4.2      4.6
Looks fine to me.
With the unit in GR OFF and feeding it a 1K 1dBu signal, (in/out midway) what is your AC voltage at the BASE of each of those transistors.
Again, AC this time.
Mike
mgalimbe said:
feeding a 1.55vac 1khz signal my AC at the BASE readings  Are:
Q3=17mv
Q14=0mv
Q4=20.9mv
Q2, Q3, and Q14 is what we're looking for.  Sorry type-o earlier.
Get the DC voltages for for Q2 like you did earlier, since we missed that one. Then the base in AC for each.
Mike
Q3=17mv
Q14=0mv
Q4=20.9mv
Mike
The DC voltage for Q2 is all good B1.04, E.53 & C1.77
The AC voltage of Q2 at the base is .178v- feeding a 1.55vac kHz tone, meter off
Q3=17mv
Q14=0mv
Q4=20.9mv
Mike
Maybe Q3 is bad or has a bad joint then.  Try reflowing the joints, if that doesn't work, I'd probably replace that one.
Mike
Q3=17mv
Q14=0mv
Q4=20.9mv
Mike
Mike
After desoldering the joints of Q3 I now get an AC voltage with the 1.55vac sine wave at the BASE of 32.5mv. is that what we were looking for? the initial reading was only 17mv.
Also I have 2 other small issues one of the VU pads on the meter board (second to last)wouldn't hold solder, I followed the traces and heres how I presently have them wired. Does this look ok to you?
Q3=17mv
Q14=0mv
Q4=20.9mv
Mike
Mike
heres the pic of the ratio board
mike
I went ahead and tested the rest of the transistors in the circuit they all look good however I noticed that I had Q11 in backwards. Unfortunately I destroyed one of the pins removing it. Just wondering if this would be the cause of my output pot not changing the VAC at the output XLR.
mgalimbe said:
mike
Possibly. Depends on a lot of factors.
Consider sending it in for repair. There are a number of issue and I can't even really wrap my head (digitally) around it.
http://www.hairballaudio.com/build-support-services
Certainly replace Q1 and Q11 and see what happens.
Mike
mgalimbe said:
mike
Mike
[/quote
Yes Mike you've been a GREAT help. I've ordered those transistors I'll install them and if that doesn't fix the problem I will send it to you. Thanks again for your patience and help.
Mike g.
mgalimbe said:
mike
Mike
[/quote
Mike g.
Good luck!
just received a bunch of jfets and tested them for idss and Vp. Just wondering which number I should use to match them I have 2 that the idss is spot on but there is a difference of 20ma for the Vp.
