tardishead
I borrowed a pair of C37a for a while and I thought they were amazing mics. Very different from the Neumann/AKG tube stuff.
I particularly like the way they handle very large SPL
So I've got a box of 6AU6WA tubes and a HK47 capsule so I thought I would build a hybrid.
And then I thought about being able use both sides of the HK47 and use a polarising scheme like the AKG c12A
C12a I have also used a lot and I think its totally underrated. Again great for high SPL duties like trumpet or guitar cab. Personally I think cathode followers are very useful and can sound huge.
I understand that the K47 style capsule gives out about 10db more voltage than a C37 capsule. So I thought its probably a good idea to keep the headroom potential of the 6AU6 and wire it like it is on the C37a with 250v HT and biased at the mid point of the load line.
Eric mentioned that HK47 capsule can handle 80v polarisation and upwards.
So heres my schematic with these ideas.
I would appreciate any help with the design - especially ideas for the values of c1, c2 and c3 or if someone could point out what the design criteria is for these capacitors. Also I would appreciate if someone could advise me how to calculate what voltage the capsule would give at a given loudness - say 110 decibels. I have not found any info on this.
