abechap024
you the man Dy!
damnyankee said:Ok, so the db range is another problem besides the meter design. Now I'm starting to understand why the dbx 160/161 cost so much new - it certainly wasn't because of the components!
So we're going to have to build something like this, correct?
http://www.electronics-circuits.net/60-db-led-vu-meter-vt69.html
Thank you, David!
DY
abechap024 said:Arska,
I'm not having the option of more than one VCA at work at a time. Put another way, people will only have ONE VCA on the board at a time. So pin 2 of the 2180 will be driven by one of the 4558 thru a 4.7k resistor and a 200ohm resistor. Am I missing something here or that should work well? Or do we need to change the 4.7k resistor to a lower ohm is using the 2180? Plus I'll also make a note of different resistor changes when using the 2180 - Like I know the 100k input resistor should be changed to 20k.
AC
Thank you, David!
DY
damnyankee said:No - don't butt out. This is a problem that needs solved. If you have the LED expertise, any input would be greatly appreciated.
The way I see it: I'm used to working with a dbx 119 which doesn't have any metering; so if that's the case with the 160VU, then I'll learn to live with it. But some type of pro metering device WOULD be nice...
DY
Insomniaclown said:David mentioned just using a fast acting DC meter in place of both the LED/VU/original metering, and re biasing it to sit at the 12:30 position. I am wondering, does it need to sit in this position? Can't we just set it up to do GR from left to right? That seems like the easiest option.
arska said:You are missing a lot.........
Here´s tested schema...... everyone, how to drive 218X vca.
-arska
