diy shotgun microphone interference tube.
im trying to mod one of these I have 2 , to make a short directional mic i have a vblock , would you recomend a dremel is good enough to cut the vents? was going to use some alluminum or cooper pipe.
the capsules unscrew., just like akg cms.
heres the specs
Tech Specs
Microphone Type: Condenser Mono/Stereo: Stereo Pair Polar Pattern: Cardioid Diaphragm Size: 0.74" (19mm), 6-micron Mylar Frequency Response: 40Hz-18kHz Max SPL: 135 dB SPL Sensitivity: 8mV/Pa Self Noise: 22dB.
heres the specs
Tech Specs
