diy shotgun microphone interference tube.
I notice all the directional mics stop the perferations some distance from the mic capsule, is this an important dimension?
i think the interference tube turns cardiod to omni untill the holes or slots are added the holes make shotgun mic super or hyper cardiod .
I'm disappointed in the non labeling of the attenuation on beamwidth charts, Oh, they label degrees on them, which I don't need, but no label on the db lines or whether they are even in reference to db. One could assume they are 3 db, but the only chart I gave seen lately that had a label, was 5db per line. Arrgh!
Traditionally, the ticks are 5dB. However, there are exceptions, typically from dishonest sources.
If you wanted the interference tube to work down to 50 Hz, it would need to be 1.7m long (almost 6 ft).
In order to keep dimensions acceptable, the pattern shifts from interference-controlled to delay-controlled cardioid.
At high frequencies; where the capsule size becomes comparable to the wavelength, the interference tube ceases to operate, leaving place for diffraction controlled directivity and masking of the rear-axis waves by the closed back of the mic.
so about 5.5 feet , 5.57743 , though would it work. if used for outdoors.
would hypercardiod be easier like my c451s use that outside.
just eq, anyway i will probably and record diologue voiceover with a ribbon. as everyone is wearing covid masks fix in post is much easier and the the one of the pm2 mics indoors. , is it easy to match a 451 to a ribbon with eq. i would think the 451 sounds kind of ribbony through bit bright.
are these good references.
I'm no machinist, but there are machinist forums just like there are electronics forums. I think you would find better answers there for this kind of problem. I think you will be dissatisfied with the results you can get from a drill press.
