evilcat
Yep, I'm ok with Script. I can't wait to start & of your projects!!!
Thank you, that's very nice of you to say. Glad you are enjoying my education ;DScript said:First of all, thanks for this thread. For me this is one of the most inspiring ones at the moment.
Yes, it had the least CV feedthrough when I measured it. I tried 1uF and 2uF and they weren't as "good" for me. For you, maybe you are OK with the added thump, depends on what you want to use it on.Script said:In the e274, is there a particular reason why C5 is 0.22uf?
You should try it yes, the circuit is rife for experimentation. One huge reason I want the boards to be 2mm instead of 1.6mm thickness and to use a higher weight of copper is for experimenter abuse. I want people to mess with the circuit, solder and desolder, and have the PCB able to cope with some learning. Because there are a lot of different things you can do.Script said:Could it be 1uf or even 2uf?
No, it won't mess anything up, it just reduces the speed that the circuit can cancel out the cv feedthrough with, so you get longer duration "bumps" of cv coming through.Script said:Or does that mess up something here? I've just been playing around with some resistor values in my mind to get a virtual "feel" of the HPF (IN, cap, followed by resistor to ground, OUT) and because I thought, if I were to build only one channel of this, perhaps I'd prefer a 10K pot (with 1uf for corner frequency at 15.9 Hz) instead of a multi-position switch. But then again, for equal left/right channel settings, pots are probably not precise enough.
Thanks! Yeah I got pretty excited. I like that in some of the samples the compressor really adds more punch and excitement.shot said:Those samples sound awesome!
For that set of samples only one fixed setting was used. I am currently working on what settings I like, which will likely be quite a vast array, so don't worry, it'll be far more than a one trick pony ;-)shot said:Did I understand right - there's one fixed setting of attack/release?
Me neither! But sorry, you guys will have to have some patience. I hope it won't take too long, but I really want to make sure I get this right. I'll have to do a few revisions before I'm totally happy. I am a real stickler for high quality, so I won't be shipping anything without being 100% sure it will operate precisely to spec for all component tolerances I am working with.shot said:Huh! Can't wait!
They will definitely be available, and I'll keep you all posted on the progress of the e274 diode comp and the eJFET comps. Both should not be too long. I think within a couple of months for the eJFET and a couple of weeks for the e274.shot said:Eagerly waiting for you to make pcb's avaliable!!!
etheory said:Thanks evilcat!
Does anyone happen to have a Fairchild 670 that they would be OK running over the original audio?
I would dearly love to have the real thing for comparison....
Even if just for the hell of it?
If anyone is up for it please do let me know and I'll send you an audio file to use.
To be honest I'd love to hear any vari-mu on these loops.
It would be great to have a processed file for each of the 6 timing settings and a few different DC and AC theshold settings.
Any takers.... :
evilcat said:I have a Tube Tech LCA 2B, which is vari-mu and have the 6 timing settings of the 670. But it have a continusly variable ratio. Interested ?
And I greatly appreciate it, thank you! Sorry again for taking so long, but work is getting busier and busier as production on the film I am working on (day job) ramps up.irfrench said:Just thought I'd drop one of those supportive-can't-wait-posts! 8)
That's fantastic! The PCB for the e274 should be approx 5cm x 15cm in size, since this gives me an excellent price/quality ratio for the PCB and more options.irfrench said:These look ace, I'm already on board for a pair jfet and u274 comps... What sort of size are the pcbs of each? I'm in a shoehorn-it-into-a-51x slot phase!
