ez1073 problem mid freq
andrea19837
Member
Hi everyone long time lurker..few post..
I have just finished a ez1073 1u rack from colin audiomainteance. Everything work. And it s beatifull.  I only have a problem. The mid freq don t work at all. Nothing. Do you have any suggestion? Thank you, andrea.
OK, i fix it.. now everything work 110%. COLIN SUGGEST AND FIND THE RIGHT FAULT:"Andrea, I expect that the switch was rotated when you fitted the pins. Remove both pins… put the switch in the position which it shows in the build manual… refit both pins. Regards,Colin Adshead"wannabe mistake bytheway It's sound wonderfull .thank you.
