T tinitoni New member Joined Aug 30, 2004 Messages 1 Aug 30, 2004 #1 hello, anybody can help? i want to use a single-side capsule. should i leave out the third pin (of back)?
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,917 Location Aarhus, Denmark Aug 31, 2004 #2 yes. And if using a single-side capsule, you won't need the variable pattern voltage from the powersupply either, so you can use a 6-pole XLR in stead of a 7-pole. Jakob E.
jeroddumas Well-known member Joined Jun 19, 2004 Messages 264 Location georgia, USA Aug 31, 2004 #3 So can this 160v be left completely out of the power supply design????
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,917 Location Aarhus, Denmark Aug 31, 2004 #4 You will off course still need 160V HT for the tube, but you won't need the adjustable 0-160V for the polarisation voltage. Jakob E.
