Hairball Rev/D R87 & CR6 Voltage Readings
core64
Member
Boston
I'm new to the forum, so please forgive me if I'm out of step with posting protocol.
I just completed the steps in building the PSU for the Hairball 1176 Rev D.  I've been following the instructions by the book, and triple checking each step as I go.
Before moving onto the next step, I was checking the voltage readings for R87 (+30V) and  CR6 (-10V) .  According to the instructions, my readings should be within +/- 5% percent of these readings.  The readings I'm getting are as follows.
CR6:  -9.05
R87:  +28.14
As you can see, I'm a bit over the allowed threshold for each.  My question is...  Are these readings still acceptable, being there only slightly over, or does this indicate a problem?  If so, any clue as to areas I should focus on?
Thanks in advance!
k
