JohnRoberts said:
Linearity a couple octaves above 20khz is not unrealistic. One obvious example is close mic'd cymbals, that could generate plainly audible, lower frequency IM distortion components from above 20kHz content not being passed cleanly.
Further, slew related limits are not always a sharp knee, but often a gradual deterioration in linearity as we approach slew limiting, so some headroom is not a bad thing to have.
Thank's to JR. My statement is a direct experience of some very good mic preamps that I have used over the years. The one I like are the ones that fit in my statement. The difference sometimes cannot be obvious in the short run but in my experience there is a huge difference when you sum 24+ channels recorded with lesser mic preamps. I suggest to investigate more on that matter instead of looking for that elusive MIX BUS SATURATION magic from the past.
To be more explicit about it here is a list of mic pres that I like and use (check the specs of that stuff if you like)
- Neve 1073 (my first love!, unforgettable...)
- Neve 8232 recording desk (recently used on a recording session, sounds close to the 1073)
- GML 8304
- Amek/Neve 9098 DMA (This is currently my first choice)
- Focusrite Isa110 (I like them but I feel it a bit "cold"
- Symetrix 528 (my first real channel strip - bought in 1985, still in use. A bit slow, useless on snare...)
- Presonus D-8 (cheap class A preamps, for a different sound)
- Api 512c - very similar to the Symetrix, but way out faster - I love the snare trough that one!)
- SSL E mic pre - noisy but nice. I love the grit
- SSL G mic pre - useless the presonus D8 sounds similar (sorry to say) - I only use it straight from the insert send to a compressor or patched to the "tape" machine (wow, that gives away my age)
Since I use my master bus plugin chain I have never had anyone saying that the mix sounded too digital.
I'm trying to share my experience and give you a way to save money, but still in sound engineering if it sounds good IS good.
