dasnevestheo
- Joined
- Oct 6, 2017
- Messages
- 187
Is there any way to link 2 units ?
scott2000 said:Reichelt No: BL 2X13G8 2,54 or similar
Mouser??
https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1-215309-3?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgbIkv1jVEs%252bM%3d
I'm guessing 35v caps are acceptable for the electros outside of the marked ones.....and what, 50v+ on the polys and ceramics??? I'm hoping the lead spacing will dictate the diameter of caps??? pretty tight layout .....
I'm actually looking at the 3.68mm diameter for resistors??? guess it doesn't matter??
Any specs or parts reference/links to the bridge needed in the PS
IDC socket and ribbon cable???
STROM 3-way connector?
2-way and 3 way pcb connector
various 2-way and 3-way connectors and headers?
fripholm said:When I buy resistors at Mouser, I usually take those 1/4 watt resistors: https://www.mouser.de/ProductDetail/271-22K-RC
Replace "22K" by the value you need.
rackmonkey said:I’m interested in 2 boards if you have enough.
scott2000 said:Maybe I could just use it parallel 10vac secondary in lieu of the 9v ac wart?????
Or are these bad for noise and hum???
TillM said:The only thing is that the 25k log pots are not in stock at Banzai.
fripholm said:Till, unless I'm doing something wrong, this is the panel for the Hammond box again.
Dateien verwechselt?!
TillM said:Thomas I hope it is okay.
TillM said:yes I saw it to late
changed the file in the post .... now it should work.
scott2000 said:Hey thanks!!
PM me if you want me to send you those pots... I have 2 now....... I can always get a couple more more... Knock on wood.....
fripholm said:Good work, Till!
But it seems, you accidentally moved the panel's 4 original holes for the rack screws and chassis screws higher up as well.
