Question about MCI power supply capacitors
astroman
New member
Hey everyone, this may be my first post here. I hope this is in the right sub forum.
I'm working on restoring my JH636 console. Cleaning, recapping, etc.
I've recapped all the IO cards, VCA fader packs, master section, and now I'm moving on to the power supplies.
I'm starting with the light meter supply (mine uses plasma meters and has a seperate PSU for them.)
It has 6 big 40v 20,000uf capacitors. I understand that in most cases, you can use higher voltage capacitors, but I just wanted to make sure in this case that it would be ok, being that the light meters are finicky and the caps are expensive. I can't find any 40v 20,000uf caps, but I can find 50v caps that are the correct size and capacitance. Just wanted to ask and see if these would be ok to use.
Also, just came to the realization that it's going to cost around $1000 or so just to replace the big filter caps in all the power supplies :(
Any advice would be appreciated.
Before replacing those, measure each of the old ones to see if the capacitance value is within 10-20% and the ESR is reasonably low. They might be OK. If not, then going from 40 to 50 Volts rating should be OK.
Bri
I've dealt with more than a few JH636 desks and seldom had any problems with the big caps in the PSU boxes. But many small caps dried out on the IO modules, especially those in the EQ section that are on the main PCB and "enclosed" heat-wise by the EQ daughter board. It's a bunch of parts including multiple 5532 opamps, all making heat!
Bri
Awesome, thanks so much. Yes, as I recapped the IO modules, I came across tons of leaking / bulging caps. Good news on the big ones. I may hold off for a while on those if they measure ok.
Beware that modern lytics have lower ESR than those of yore, particularly if they have a higher voltage rating (I know it's somewhat counter-intuitive, but it's recognized), which may result in increased stress on the rectifiers and/or transformers.
I am also rebuild an MCI 636. This has not been used for many years and I am just starting to go through it. A couple of questions. I don't see any bulging or leaking caps but there are loads of Illinois caps on the boards. Can you check the caps in circuit accurately? Also, I know there are some bad 5534's in there. Is there an advantage to replacing them all as long as I am in there?
you can probably tell if they are bad, might not be accurate enough to confirm value.
only if you have too much money
+1 to what John said. WRT the caps, you can usually check them in circuit with something like the Peak ESR/Capacitance tester. Most of the time you will get a good reading in circuit, sometimes you will either get no reading or a message that says "In Circuit/Leaky", in which case you will need to de-solder one end of the cap to measure it (for axial caps), or remove it in the case of radial caps.
On the IC front, I'm not a fan of wholesale IC replacement, but you will definitely need to have a hard look at all of the IC sockets. If you have the red sockets, they will probably need to be replaced.
Good luck, a 600 can be a beautiful sounding desk once you have exorcised all of the gremlins.
The big caps in the PSU's will likely need changing. They work very hard for a living and I have seen them go completely!. Make sure you replace with expensive high ripple rating versions. The big caps on the power rails in the console not quite so important. If you have tantalums in plasma meters get them all out immediately. They go off like popcorn!. As for the rest I would do a 5% rule. By that check out 20 of each value and if you find a faulty one then check another 20. Often you find a specific value that has a high fault rate. I am not a fan of wholesale replacement for the sake of it. You will do more collateral damage to the pcb etc than you improve. if you find red IC socket holders get them all replaced. The best improvement you can get is to replace as many of the old tin plate Molex connectors. They are a big source of the MCI reputation for being munch, crunchy and intermittent. Use gold plated ones from Mouser.
I am still going through my 636 and it is physically missing a few TI SN7474N op amps. Mouser says they are discontinued. Do any of you know a good replacement for them?
You can still find variants from other logic families, like 74HCT74 or 74F74. Might have to check to make sure the signals are not ringing too much if you replace the original with a faster family.
Bri
Brian,
I am trying too find some axial, nonpolarized 47uf 16v, 100uf 16v and 220uf 16v caps for my 636 and am having a problem finding them. I usually use Mouser and Digikey. any ideas where to look for them?
Mick
Brian,
Mick
If physical size is not too big of an issue, you could consider widening the search to 25v rated caps..?
Brian,
Mick
It would certainly help if you went into your "GroupDIY Account Information" and updated it just a bit to include -- WHICH COUNTRY YOU ARE IN -- in order to assist the forum members on here to know how and where to assist you!!! If you are located in Belgium, Nigeria or South Africa.....it won't be of much help for someone like myself to find what you need here in the U.S. now. Ya dig???
With that said.....the below included link will show you a plethora of non-polarized capacitors of and around the value(s) you are looking for. Just choose which supplier may best suit your needs. And.....as Khron has stated, not knowing the actual physical size of each of your capacitors puts a crinkle in trying to find an exact replacement for you, but in any case.....I have seen that there are 100V non-polarized capacitors that are about the same size as a 16V capacitor, so.....if that is all that is available, then I'd go for it!!! Here's the link:
https://www.ebay.com/sch/i.html?_fr...1-156598-222121-3&crlp=663746069967_&device=c
Once you are on the web-page shown above, you can then easily enough change the search terms in order to zero-in on more of what you are looking for.
47uf 16v axial electrolytic capacitor:
https://www.aliexpress.us/item/3256...sea!US!3239845106!&curPageLogUid=rbW72VztfcGc
This supplier has 2 of the 3 values you are looking for. However, they are 100V capacitors, which may or may not fit within the room that is available for the 16V capacitors. Knowing how much room/space is available for a replacement capacitor would be a BIG help!!!:
https://www.alibaba.com/product-det...993.html?spm=a2700.details.0.0.17a874fbzgv7Vv
If you can get together a "BOM/Parts List" detailing specifically the information about each individual capacitor that you are needing, including the BIG VALUE capacitors and you send me a PM, I could put together a quote for you and submit it to some of the overseas suppliers that I have purchased from. This would need to include the quantities for -- EACH VALUE -- and what budget expenditure can you easily afford. If you can read/see a MANUFACTURER and/or PART NUMBER on these capacitors, that will also be a big help!!! I am guessing that since you are preferring to recap the entire console, that the quantities may be in the "few dozen" per value. That actually is an advantage, as most overseas suppliers offer their components in quantities of 100 or more. > NOTE: Last year I had purchased a box of 30,000uF 100V PCB-mounted electrolytic capacitors that I am planning on using in the power-supply of an "200W/Channel audio amplifier clone" project I am working on. I thought that their price was more than reasonable and the shipping from overseas to me here in the U.S. was only about 2-weeks. Just sayin'.....
I have performed over $3,000,000.00+ worth of "Electronics Purchasing" (NO!!! I am > NOT < doing any "chest-thumping" here!!!) and perhaps some of my experience just might be able to help you out here. But, I need a "small boatload" (perhaps a "dinghy"???) of information from you first before I can do anything.
Just sayin'.....
