Kilohertz
Member
HI boys and girls,
I have had this Sta- Level for about 15-18 years, and am just getting around to putting into use. It's pretty rough, but seems to be all there. The input xfmr had come off the back, hanging by the wires, and much of the insulation had fallen off. I managed to get heat shrink installed and that's all fine, hopefully got all the wires to where they should go, but I noticed there are 3 extra wires coming out of the xfmr, should these just be insulated and not used? I can't find any good inside pictures on the web, the schematic only shows 5 wires being used, 2 in, 2 out and a shield. What are these extra 3 wires for?
2. For studio use, +4dBm, do you remove the input/output pads or leave them in place?
3. It's been re-wired for 6BZ8 for V1, I'll try it as is before searching for a 6386.
Otherwise it's all original and should probably be re-capped, at least the PS caps.
Any help will be much appreciated.
