Right. I was aware about the Johnson noise generation principle etc. What it was not clear is: how it is possible that: with same motor and (as far as I've understood from what I read in internet) similar circuitry, the level of this noise is so important, when the elements between the mics (the 2 types I considered) are almost identical (I'm talking about the motor) and both they don't use any circuitry than a Transformer.
I'm aware that everything is put on the signal path generates intrinsically noise, even wires (thus: also Transformers), but I was wondered about: so loud noise.
I was not thinking to impedance mismatch, you put in highlight, where a big loss of signal of course deteriorates/worsens the S/N Ratio.
Based on your indications, I re-read your previous message related to your RB500 and I checked the Input Impedance of your Pre. Indeed I noticed that, indeed, their input impedance are too low to be matched with the 2k5 you have in your RB500.
So that, I was wondered that the author of that review had the same issue.
He has(had) a Aphex 1100, as declared, and I wanted to check its specs:
http://www.aphex.com/pdf/1100/Aphex_1100_specs_only_1pslip.pdf
What I found is: no indication about Z-In.
Thus: your suspects are full reality. At this point I think the author of that review couldn't check the mismatch: he had no indications that could warn him (it's my opinion, so I can wrong).
At this point I need to check the input impedance of my Board and to verify the necessity to buy or build a Buffer.
