C.B. - Boudio
I have in the last couple of months been trying to design some equipment. My plan is to set up a ultra-low-budget studio with later 1950s-early 1960s-inspired equipment. I want to do most of it by myself, which translates into 'all except microphones and recorders', so the preamp/mixer, EQs, and compressors. For the compressor, I will probably use the 'mix bus compressor' as now being built on the forum.
My last - and maybe least-embarrasing! - attempt to design the mentioned equipment is this small 4-into-2 mixer.
It features an EF86 and an ECC82 per channel, plus a ECC81 in the master-section and an EM87 as a peak indicator (I will use also normal VU-meters, maybe I wil just make a scale on a regular mA-meter).
Per channel, there is also a rudimentary equalizer, not as a precise kind of adjustment but more like some knobs that may affect the frequency response, to put it that way.
Transformers will be bridgeable, so I can leave them out (because of budget - it must still be decent!), by means of a 7-pin DIN connector; each audio transformer will have its own subchassis, connected by such a plug.
Every connection between 'modules' will be patchable.
Here are the schematic drawings. If there is something you don't understand, feel free to ask of course.
