chilidawg
- Joined
- Nov 27, 2013
- Messages
- 177
Howdy,
I need to replace the gain pot (RV9) but local vendors in my country are selling only single 5K log or dual 10K log pot.
I understand the schematic says it's a single 5K pot, but the board wants a dual because the front pins of the pot are used for mechanical support and also because if I put in a 15mm shaft length single pot instead of a dual, then the shaft will no longer protude enough for the collect knob to grab it. A 20mm shaft length log pot is even impossible to buy.
So my stupid question is, do I need to modify the circuit, or can I just drop in that 10K pot and be done with it?
because according to SSM2017 datasheet; with a 5K gain resistor, the lowest voltage gain is 3 (around 10 dB)
G = (10k/5k)+1
therefore with a 10K, that would be 2. No idea what's the equivalent in decibel, but it shouldn't matter much???
Please correct me if I'm wrong.
Thank you!!!
G = (10k/5k)+1
Thank you!!!
